swmichsx
i put the front shocks on yesterday , very easy no problems. i did notice that the sway bar end links now hit the trailing arm. i am guessing that if i lengthen the radius rods this will take care of the issue? if you did that did you also and a spacer and a longer bolt where the trailing arm bolts at the back?
I've got viper shocks in my 97sx.No problems with the sway bar hitting anything. Did you remove the shock mount and bolt the shock up in the chassis?
swmichsx
i figured it out. someone at some point had the radius rods too short. adjusted them out and im good to go.
