1973 GP292 one lunger with no spark
snomofo
VIP Lifetime Member
Anchor Bay, Michigan
Okay fellas, one of the neighbor kids brought over this wreck Saturday and asked if I could get it running. No spark.
It looks like a 1973 (sticker on the block says 640 1973) and it is in fairly decent shape for this vintage. The coil shows no opens.
I assume it has a set of points, am I correct?
Any help would be appreciated... I've got a face cord of wood in my future if I can get it to light.
292
Yup points are behind the recoil, you can see them through the rotor after removing the recoil. Try using a steel fingernail file and clean the points top and bottom, just be easy not to remove too much or deform them. Then using a piece of a business card, spray the points clean with brake clean and run the piece of card through the points a few times until the card comes out clean. Wish I had one of those again, BIG fun on that old sled !!! Good luck
Excellent! Thanks Sparta. I haven't used my old ignition files since swapping the dual point distributor in my Cuda some 15 years ago. Thanks again.
