Updating 80 enticer rear suspension
mthier
brandon sd
Has any one out there ever updated the suspension in a early 80s enticer. I would like to give my sons sled a little more travel and purchased a suspension out of a late 80s enticer. The sled had the same track # so I didnt think length would be a issue until I went to bolt it in. The measurements between the mounting bolt were the same out of the sled but when I was installing the holes didn't line up and the track was so tight with the skid collapsed that you could have played a tune on it. Really dont want to have to mess around with drilling new mounting holes and reinforcing the tunnel if I dont have to. Thought maybe a little longer track like the phazers would work but will probably have to change the drivers. Any help would be great. :o|
I had the adjusters all the way forward. The old suspension probably has about 2" of travel and the newer skid probably had 8 " I am going to check out the link. Thanks
