Ride-4-Life
Im just wondering, I have a 2000 SXR 700, and is the flywheel left hand or right hand thread. Before I remove it, I don't want to try and mess up.
taylzee
If you are talking on the generator, you remove the nut on the shaft and then use a 3 bolt (steering wheel) puller and it should pop right off the shaft. This is of course after you remove the starter ring. You will need some fairly long M8 bolts for the puller.
