shavedheadedyamaha
i know its not a yammie but hey its stiil pretty bad.....
[/IMG]
[/IMG]
Yamidude59
nice sled...
horkn
Nice, what has been done to it?
I keep wanting to mod out my 00 XCsp, but it always runs like a champ, so I have no reason to.
03viperguy
still have the srx too I see nice sled
shavedheadedyamaha
it has a made tunnel, bar risers, slp pipes and custom stingers, boss noss kit, a 156 track, vforce reeds, high compressoin heads with the changable domes, the avenger III race pace for water egts and rpm, boss seat, and aftermarket skis... other then that its stock...lol
shavedheadedyamaha
i am having a headlight problem it just keeps popping them??? i put one in it gets bright when i rev and pow its done its good at ideal
Snowsnake
Voltage regulator.Either not well grounded or defective.
shavedheadedyamaha
cool i was hoping that wasnt the problem but a bad ground whould cause it to ramp up?? and that could cause more problems to right?
Roost 'Er
Stator produces more power at higher RPMS thus creating the ramp effect when you rev it, basically the output is purportional to the RPM, now without a volt regulator the voltage will just keep increasing. By the sounds of it 100% volt regulator. Usually down by tunnel and is bolted in, has a two prong plug going into it
Bad ground would be more spiratic increases or peaks in power. Like a flashing, or a surge.
