How big of a lug?
Phillip Schichtel
UP Michigan
I have a Phazer II. I am going to put a standard 121" track on it. However, I want to get a 1.5" lug, with this clear the tunnel or do I have to drill new supension holes to lower the supension ride height? thanks
I believe you can use a 1.5" track if you change over to small drivers on that sled. Not positive though, so you might want to take a look at the sled and measure how much room there is above the current track between the tunnel on top and in front of the skid.
Im with ryan. I put a 2" paddle on my sxr and only thing i did was changed the drives.
On that phazer I would go 1-1/4 and not change anything. gets costly for another 1/4". For the 1-1/2 and 7tooth drives you will loose some top end.
With my 2" paddle and smaller drives I still lost a little top end..but it ROCKS in powder.
Good luck Brent
