devvy2
I have a set of simmons dual-runner skis, they track great but steering is heavy. What type of ski should I go with or is there something else I can do?
if you like how the skis track, buy a set of kimpex arrows, easier stearing, no darting on plowed roads like the simmons, all the straight line handling of the simmons. a little less floatation, and they look a ton better.
mod-it
You could try loosening your limiter straps a little at a time to take some pressure off of them. Just don't want to go to much and have them clear off the ground. The straps will allow more transfer and take some pressure off when your on the throttle.
