Yamidude59
Just wondering why the level in my puke tank is so low, before i went out to ride it was at the cold level, just got off the trails about 2.5 hours ago and the bottle looks to have only like an inch in it, wheres it at?
still not cool enough yet to go back into the tank? motors cold, exchangers are cold.
Yamidude59 said:Just wondering why the level in my puke tank is so low, before i went out to ride it was at the cold level, just got off the trails about 2.5 hours ago and the bottle looks to have only like an inch in it, wheres it at?
Are you leaking....?
Yamidude59
hard to tell, sled is defrosting in the garage right now, water and snow everywhere. i removed the carbs a few days ago and i installed all the lines, and my exchangers are fine, i had no overheating problems on the trails, exchangers were warm like they should be.....
I was out for 5 hours today with no problems, just noticed the level a little while ago when i went out to close the hood.
I did spill some coolant when i pulled the line off the carbs, came out pretty fast and furious, but not for long, not long enough to make the level go down that much, i'll check it again later.
Let it sit tonight and check tomorrow morning again.....Sometimes it will take a while to come back, if not fill it up and go for a ride (I'm sure you where plannin anyways right.....?) and check again, maybe check on the trail also.
I know I'm not giving any huge help/advice, just throwing some ideas here and there.
Nick
Nick
Yamidude59
i will go ride tomorrow for sure, I will check tomorrow and get back to ya. thanks for your help!
i would say your fine,you just lost some from the line R/R....top back off and watch it...
