Reed spacer thickness
Bob Brown
NH
Does anyone know what thickness is needed for a reed spacer? I looked at the plans under the tech section and it looks like 7mm. I am trying to find out if 4mm is enought to open the port such as the reed notch fix.
put two 4mm together..4mm alone wont help much.but it would be better than nothing, also. just have to watch that it dos'nt hit the steering column...might have to shave alil off your carb where it hits!
