marty f
cannot get the bolt that holds the ski too slide out its a 1997 vmax,any help
yep them suck for sure,did you go after it with a BFH and punch???
had one stuck so bad once i ended up taking ski, spindlle and all to the press. your going to need a new bolt when your done. pb blast, roll the sled on its side. let it sit, soak it some more, and the ever helpful BFH.
FuzzButt
If it is any work to get it off then take the spindle/ski combo off the sled and work on it on a bench like Snowdad4 suggested. It is so much easier to work on it when it is not at floor level.
Also a punch on the end of a air chisel really might help out over a BFH.
ExpertXViper
The bolts corrode themselves to the collar that sits inside the spindle, which is the cause of your problem. As others mentioned, a decent size hammer should get the job done but youll want to replace any of the hardware that gets damaged during removal. Good luck
I will still cut it with a sawsall metal blade.....Easier and faster....
Nick
Nick
sockeyerun
Test Dummy
BFH and punch or wood, it'll come out.
marty f
Sawsall Worked Great
Sawsall Worked Great,thanks
