Comet 108 or 108EXP
Vmax540
Clarion Pa.
Website
vintagevmax.com
Trying to decide if this is a 108 or a 108 EXP ? One would think Comet would have stamped a part# somewhere ! ? ! I need to rebuild and the catalogs show various different part #'s for pins, weights, rollers, bushings. If this helps I bought this clutch new from Reichards in 1998 and it has the wide rollers and red paint on the weights .
comet clutch
That is a 108exp . There is numbers on it ,i think they are on the back of the fixed sheave ? I have the original papers from back then , if you list the numbers i will look them up .
Easy way to tell, On the 108 there are 2 bolts closer together, a large gap, then 2 bolts closer together. On the exp all the bolts are evenly spaced apart.
