Brake light not working...
akrievins
Mississauga
Was out this weekend and noticed that my brake light would not come on when I held the brake lever. The running light works, but it doesn't get brighter when I apply the brakes. I'm hoping it's just that part of the bulb, and I simply need to buy a new one. Anyone else experience this kind of thing.
This same thing happened to my Yamaha Phazer II, and I never did get it fixed. I changed the bulb and looked at all the wires and connections on the Phazer.
My lbreak light stayed on all the time, like i was applying my brakes at all times. turns out the part that connects to the brake lever was loose and got jammed, i had to remove the bolt and reinstall, i would check to see if your bolt is loose, everytime you press the lever, the pin slips out not engagin the switch for the brake light...that my suggestion
