RIVERRUNNER
Hey guys, I am wondering if anyone else has problems keeping there w arm intact? I have had the my srx for four years and every year I have to re weld it. I have done the fix that everyone says to. I also have added extra steel where others havent. I am 160 pound rider with gear and I like air every once in a while, but mostly I trail ride....any suggestions? Is a h arm better? Do you guys still crack them? Any help would be great!!!Rob
cracking arms are caused by the arm bottoming before the shock does and the reverse flexing caused by the way the straps go over the arm holding large forces from the huge front spring with alot of preload.
read below
read below
RIVERRUNNER
Ok guys, I have read all your posts betheviper about 50 times in the last 4 years......That is how the skid is setup to begin with and I also have a yamaha manual for my sled and have finally got my sled to soak up some bumps(proaction) without my back suffering....so I guess I need further info on how to get the w arm to survive without f-ing up the rest of my skid settings. Or is that not possible???
