cjhofer
I have an '02 Viper. Its pretty much stock. It has about 2000 miles on it. When I goose the throttle from a stand still or low speed the engine bogs down. If I kind of feather it up to higher rpms and speed and then get on the throttle it will really move. I just did a thorough carb clean and power valve clean. I put new plugs in it. It has always ran great in previous years under the same conditions. Any thoughts on what to look for or try?
mod-it
Have you tried flipping the choke lever to see if it helps? If it does, take carbs back off and re-clean pilot jets. You absolutely have to look through them and make sure you can see a tiny round hole through them before putting them back in. Or, the fuel screws didn't get adjusted back to where they were set at. Easy to miss plugged pilots if a little inexperienced at carb cleaning (just guessing, don't know if you are or not), I've had to pull them back off a couple of times (I never learn the first time, lol).
Spot on, but if you don't find anything check your TORS and clutches.mod-it said:Have you tried flipping the choke lever to see if it helps? If it does, take carbs back off and re-clean pilot jets. You absolutely have to look through them and make sure you can see a tiny round hole through them before putting them back in. Or, the fuel screws didn't get adjusted back to where they were set at. Easy to miss plugged pilots if a little inexperienced at carb cleaning (just guessing, don't know if you are or not), I've had to pull them back off a couple of times (I never learn the first time, lol).
