hunter78
Can you you safely run some carb cleaner through the system on a MM 700?
Ding
Darn Tootin'
Sea Foam or Ring Free are good to use. What are you trying to accomplish?
S.S.Viper
Wow...I just put in Sea Foam yesterday...huh and WOW, I'm impressed...I put some in the mornin...walked away for a bit to let it work in...started it up..smoked like crazy...turned it off...when I came in last night...not even half a pull on the cord..go figure...however..its not the easiest to pour in there...(no spray version)...but a straw helped on the jet holes...and poured it into the top of the carbs(covers off)...
Thanks to you guys for talking about it...
