dirtnut67
- Jan 29, 2004
I just bought a 99 srx with a bunch of clutch mods. It has heavy hitters for wieghts. 911 respons clutch. encapsulated roller secondary.
I would like someone to give me the best setup using stock clutch parts. Turk use to have an excellent setup but I can not find him anymore. Any help would be great. Thank you
Turk
TY TECH ADVISER
- May 2, 2003
I can,t help you cus I don,t know squat about the ER roller secondary. As long as the sled is pulling 82-8400 rpm & the clutches are aligned & centre to centre is good you can,t ask for more!
Turk
TY TECH ADVISER
- May 2, 2003
I would use the 8dn-20,s from a 00-02 SRX, 4.5 gram rivets in each hole, w-w-w primary spring, stock helix 80 degree wrap with red secondary spring.
jwifferdill
Life Member
Is the SRX a 600 or 700? The Heavy Hitters are a very good all around weight. It is nice to be able to adjust them if you need to, and I noticed significant performance gains over stock with them, helix change, and primary spring change.
