warning light on 02 viper
xviperx7
Wiscasset
i was driving around on my viper today and the yellow warning light came on so i stopped and set for about 20 seconds and it went off drove again for a few and it came back on any ideas on whats going on? thanks :2strokes: :letitsnow :dunno:
DCS light?(detonation control system) Its whats keeping your motor safe from Low octane or "bad" fuel. You are risking your motor by running bad or low octane fuel through it, are you using new gas? the highest pump gas octane you can get? if not, then run the highest ocatne, (92 or higher)
There should be another indicator lit up or flashing. Make a note of everything that is lit or flashing on the display. If it is flashing, count the number of flashes and how long they are. Then go to the Owner's manual or the Tech Pages to see what it means. If you can't find it, simply post what you see and we can help.
