sm31
I'm considering buying a Canadian 2000 srx 700 with 15000 kms and an original track. Please give your opinions on the pros and cons, as he's asking $3000 CAN. No major engine or shock work has been completed on it. It has had regular maintenance and heavy northern trail riding. Thanks
check the compression and the w arm in the suspension for cracks
blueblooded
With that many miles,the clutches are probably due to be rebuilt,shocks recharged,jackshaft and idler wheel bearings,bushings in suspension at all pivot points(these are plastic and wear out often),reeds.......Just things to consider while your making an offer.
