Good clutch set up for Viper?
superclean
Holland Mi.
Looking to improve on stock 02 Viper. What clutching do you guys suggest ? I ran HC's in my SRX's but didn't care for the inconsistansy. ?? Thanks
what inconsistancies, did you get w/the heel clickers?
the tech pages has some clutching setups by turk.
there is also a chart, that has some clutch setups, contributed by a bunch of members, that you could check too.
could not get r's to run consistant. When it was on it was a rocket. Had a 51/37 dalton helix, Might have been a little much to pull on top end. Had to be -10 or colder and then it would fly. Tryed lightining up the tips but ended up wadding the sled before I figured it out. Sold set to Yammiegod and took a year off. Now starting over with a Viper.
37* doesn't sound to be too steep to try and pull on top end, as many other users on here use finish angles of 38* or 36*. sorry to hear you didn't have the best of luck w/them. did you check the tech pages for some of those clutch setups?
I can't seem to find the tech pages. I am not to bright on this laptop, can someone direct my dumb@$$ to the right spot? Thanks
Turks Tuning Tips (SX Viper clutching)
New 2002 & 03 Viper Trail
53/43 Helix, Green Secondary Spring & Everything else stock
New 2002 & 03 Viper w/Heelclickers
50/40 Helix, Red Heelclicker ,4.2g in heel, 1st hole empty, 4.5 G in the tip with Green Secondary Spring. Also can run a 48 or 46 initial angle & 2.4g in 2st hole and a little less in the tip.
