07 GT
Can anyone point me in the right direction on where to find the Yamaha diagnostic trouble codes for a 99 Srx 700?
My buddy's sled keeps flashing codes and can't figure out what they mean. He thinks its overheating but im pretty sure its not.
Ive tried a search for this but come up with nothing.
Thanks.
Thanks.
what is the flash sequence?
07 GT
Im not sure of the exact flash sequence but the coolant temp lite is blinking after riding about 20 miles or so.
The motor doesn't feel hot, the heat exchangers appear to be circulating ok. The motor is fresh. New water pump/oil pump shaft, bearings a seals. The coolant is circulating. I popped the cap off to verify this.
I need to ride the sled and have it act up on me to see the exact flashing of the light.
otis700
codes
My srx was flashing the temp light ftoday or 7 flashes then repeats which per the tech page is the servo motor / power valve related.
Mark
Mark
vintage srx
Sounds like a internal break in a wire or a wire shorting out.I had a simular problem but it was my knock sensor.It ended up being a internal break in the wire for the knock sensor.
