milleniumsummit
I need help....I started the sled today and it ran fine until it was warmed up.. Now it wont rev high enough to engage the clutchs. If you cover the air cleaner the sled will rev higher and all is working normal.If you keep it revved above 3000 rpm it will work good. The belt is worn and sits below the clutch lip. Could the worn belt be causeing the revving problem ??
Have the carbs been cleaned. When you cover the air cleaner it is like putting the choke on, thus saying it is starving for fuel down low. I'd bet the pilots are plugged. Maxdlx
milleniumsummit
They were cleaned at the beggining of last year. I will take them off and clean them again.
