Tod
I think this was just talked about not to long ago ........ but what is the part number or description for the larger than stock yami wheels for the four outside wheels to use on a the 97 and later skids.
do you also replace the two inside the skid?? Can you feel a difference when rotating the track by hand?
Thanks,
Tod
Thanks,
Tod
http://www.totallyamaha.com/snowmobiles/aaTECH/Suspension/Hyfax_Saving.htm , scroll down to technique #4...the inside should be just normal pol or doo wheels
Tod
Thanks Sleddy,
I should have known to go check there first.
No Prob...hope things are good Tod...hope you can make some of the Muni rides again this year
actionjack
tod
My 97 sx7 does not have the plastic spacers referred to on the tech page so I have ordered different bearings, plastic spacers and the yamaha wheel bolt kit to find out which will work.
moab11
do you have to get the new wheels with the bearings installed, or do you use a different bearing?
Jeff
Jeff
depends on the shaft dia you need...the older wheels maybe have a metric inner race....not sure
