Anyone know how to fix the idle on these things? I've cleaned the carb numerous times but cannot get a steady idle.It idles up to the governor and then down to a stall almost.
Also, who knows the trick to bypass the governor with a zip tie. My 8 year old is in need of a little more speed.
xsivhp
just use a zip tie to shorten the chain on the governor and you will get a little more from it.
Would I zip tie the governor spring tight or leave a little slack in it?
