Phazer track pitch?
BarneyMN
Minnesota
are all phazers 2.52 track drive pitch? I found out 1984-1989 phazers have a 12 spline drive shaft and 1990 -1998 phazer2 have the 15 spline (for gears). I have a shaft from an older phazer and was wondering if I can steal the drive sprockets off it to put on my 96 shaft or can I use the old shaft and just put the 12 spline gear on it? I'm asking because I want to be able to switch tracks without pressing drive sprockets on/off, going from 7tooth to 8tooth drivers.
Phazer Tracks
1984 - 1989 phazers are 2.52 pitch , 15" x 116" tracks . 1990 and later phazers are 2.52 pitch 15" x 121" tracks . I think the diffrent phazers have diffrent chains so the gears are not interchangeable .
Yeah I agree the gears are not interchangeable....old ones have 12 splines and newer have 15, didnt know about different chains?
The above is correct, both have the same pitch, just different length tracks. I longtracked a Phazer 1 years ago and never had a problem.
