Too high rpm
SRX999
Quebec
When I snap the throtle my rpm is at 8800.What can I do too recuce it to 8100 top 8400?It is a SRX 700 1999 with 8dn-10 (gold)rivet on each hole, Orange primary spring ,Bender helix 9970c(position 6-1)black sping,reed spacer,coldair kit and bender can?Thank you
I am not very familar with yamaha.But I have a rivet in each hole.How to know the weight?How much gramm to had to drop the rpm?
Usually a gold rivit is the 17.2 (long steel 4.5gram). SRX999 did you buy that clutch kit from Bender? Check your rollers and weights, do they move freely, any slop? Two ways you could lower your engagement rpm's is to go with a lower preload primary spring or go with a higher initial angle on your helix. I sent you a PM with more questions.
