Hi guys in Wisconsin and started throwing a code. Eight flashes of the red light and coolant light then it pauses and starts over. Coolants good and doesn't appear to be overheating at all. Have rear exchanger too.Any ideas? Thanks
harness racer
8 flashes- the fuel level sending unit
7 flashes - power valves / servo motor
chilli
not to hijack, but is there a link or something to show all diagnostic flashes?
its in the tech section
maybe too low on gaz
You likely have a bad temp sensor, or a wire or plug loose in the temp circuit. The flashing light indicates a problem with the circuit. Make sure the plug is pushed in all the way, and that the wires are not damaged or come loose.
