srx hand warmers
jordan
saskatchewan
hey guys the hand and thumb warmers on my 01 srx arent working any common issues with them i noticed a orange and white wire in the wire harness have been cut off might this be the cause
yellow and red for handwarmer and light green for thumb
well that sucks where are these wires supposed to go and is there any likely reason why they would have been cut
check at cdi if u have 12 volts on the yellow with a red stripe with the motor running at 3500 rpm with resistor at maximum............
if u have the white and the orange cut the engine will run only on middle cylinder ....if it run fine maybe someone put new wire
yeah i was wondering about that cuz it does run on all three thats likely what went on but ill check for power at those wires thanks guys
i guess someone before u cut those wire and fix them somewhere in the harness and let the old wire there
