SRXPete
Will an 04 Warrior skid bolt into a 2001 SRX?
I have a 03 RX1 skid in my 00 SRX which just was a bolt on and it works great.
01 msrx
the front bolts will bolt up but the center and rear bolts have to be drilled plus you will need the rear drop brackets.
Not without adding some rear drop brackets from a Mountain Max for the rear and relocating the holes and supports for the center shaft . I put one in my Viper a couple years ago . It wasn't to bad a job .
SS .
SS .
YAMAHIZAL700
Very interesting, so this would be the same with say the apex and all newer skids?
Sneey Snake helpped my roomate and i a couple years ago installing a Warrior skid in a SRX and he even sent us the template to cut holes. Thanks again sneeky snake. I would like to return the favour to another fellow TY member. I still have the template so if you decide to install the skid let me know and i will send you the template.
