kidd88
I just picked a sweet ET250 except it was locked up. I pulled the head off and used sea foam and WD40. I got if free. Its got good spark and good compression. Im just not sure what torque spec is for the head? appreciate any help.
			I see you haven't gotten any help yet. I don't know about my Yamaha but both my 80's era Arctic Cats say 12ft/lbs first time around and then up to 18ft/lbs for the second round of tightening. That's it. They don't require a lot. Like I said though - those are arctic cats and I could be way off in the Yamaha world. I'd problably call a dealer and speak to a mechanic.
			go till you hear your elbo click....
			sandmanmike1
Marvel Mystery Oil works wonders for freeing up locked up stuff as well.    The decompression switch hangs up on those too.   You want a parts sled cheap I want to unload it fast.    It could be running in a few hours with the right guy messing with it.    Has new belt and new hyfax.    I was in the process of converting it to use a mikuni roundslide and had it running just need to fine tune it.
