RUPP-NITRO
I have a 95 vmax 600 and the motor to y pipe gasket leaks.
Is there a after market one thats better than stock or will new
ones do the trick? Thanks
a new one will do the trick,to help add just a thin layer of hight temp
sealent on the gasket(steel crush O ring). use OEM.
braindead1684
Ditto, i use the hightemp exhaust sealant on the ring and the flange of the y pipe then install NO leaks,
also i have heard of using regualr gasket material instead of the crush rings but have never tried that method.
