SRX skid shock info?????
98700
Wishing for snow!
Hamilton, Ont
What are the Diameter of the eye openings on the center and rear Skid shock?
What are are the Opened and closed length of the SRX AND VIPER shocks???
i have both shocks from a srx rite here ....the front shock hole is 0.890.or just over 3/4 of a inch..on both ends with no bushings in it ...and rear shock measures ..0.400..or 1/16 less than 1/2 inch and the bigger hole measures the 0.890 also ....hope this helps
the smaller shock measures 12 inches from center to center uncompressed.....and it will compress 2 1/4 inches so compressed it measures 9 3/4 while compressed fully ....and big shock is 17 inches uncompressed ...with rite at 4 inches of travel which makes it roughly 13 inches fulley compressed
crewchief47 said:
1mm = 0.03937"
Perfect, thanks Ian.
Also Does anyone know of a shorter shock that will bolt right in? I got a viper shock now it's to long for what I need.
I think the srx is the shortest and probably the same as a sx.If you need one let me no and i will give you one.
OMG! What a nice guy. I am in need of one too. The viper shock is hard to lower of speed runs. I'll take it.
Yeah the longer spring/shock is to long to wind the spring right off for what you want to do.pm me a address i can drop it off.Somewere i can stop with a semi would be best.
