Need help with SRX idle and initial throttle response
01&02SRX
Grafton Mass
Hi Lookin for a bit of help I have an 01 Srx which was not ridden much year due to changing front and rear suspension however ran fine when loaded in the trailer for summer storage. It runs crisp and clean at half throttle or better but when idling and low end it has no throttle response and sounds like a fouled plug! I have cleaned the carbs checked the operation of servo, adj choke and throtte cables, and still will only idle on full choke and does not sound crisp. I am guessing i really didnt get the carbs clean enough the jets i guess?? Help me Thanks :letitsnow
your pilot jets and pilot circuit passages, aren't fully clean yet. you'll have to pull the carbs back off and take out the fuel screws and pilot jets. spray out jets and pilot circuit passages w/carb cleaner and compressed air. then put jets back in and put fuel screws to 1-1/4 turns out. i know yamaha's spec is 1-1/8 turns out, but i've had better luck with 1-1/4 turns out.
I was in the process of cleaning the pilots when u guys responded and you all were right havent tested it on the snow yet but sure sounds and feels good in the garage
Thanks Guys :letitsnow
