shelbygirl29
How do I clean the powervalves on my Srx 700. I don't want to bring it in to the shop. Please help!!
There are VARIOUS threads on this. Search feature in above.
But..........
The easy way is to just unbolt the 4 little allen headed screws holding the housing to the Cyl, Slide out the valve and clean in REALLY good, then slide it back in. I like to take the ENTIRE setup apart, But then again I'm kind of anal, and expect 199% performance from my sled. Be sure to adjust them also.
Nik!
But..........
Nik!
Yamidude59
link in my sig. for proper adjustment procedure.
don't use a scraper to high of risk of scratching off the coating,remove
the valve like 98700 explained and use a good solvent cleaner for carbon
and good old elbow grease. may want to soak them for a wile too..
