7.5" wheel ????
Concept Carbon
Ottawa, ON.
Hi I last season I replaced all me small wheels with bombardier 5.250 wheels instead of the polaris wheels 5.350 only reason was got the wheels cheap.
So can I run the older style 7.5" srx wheels with the 5.250 wheels the wheels actualy measure a bit more then 5.250 if i remember correctly
yup.I have them 7.5 rear wheels for both my sleds.And I have the Polaris size idler wheels.My Hyfax hasn't changed that I have noticed that much at all.
Yes sir. Was thinking about doing that to mine this year. If memory serves, a post by MrViper said you need to cut the axle spacers a bit because the old bearings were wider.
Yes Yammer that is 100% true.
thanks aware of the spacer issue, just want to check if my 6 idlers at 5.250 will be big anough or do i have to buy new polaris ones.
