deepnsteep
ok i just measured mine from the center of the w arm bolt to the center of the rear bolt is 27 inches .....but thats on a stock 98...not sure if 2000 was different .....hope that helps
dirtjumper895
Ill try and rememeber to measure my 04 tomorrow and will report back.
dirtjumper895
dirtjumper895 said:Ill try and rememeber to measure my 04 tomorrow and will report back.
I measured mine and got real close to 29 inches..... Huh.... I think we need another few people to measure.
mountainx
- Feb 23, 2004
I got 28 7/8 c to c. Thats to the shaft hole in the drop braket in the rear.
deepnsteep
Good deal....I'll check the measurements on mine. Thanks for the help guys!!
I have an aftermarket tunnel on my old 98 with 2000 geometry suspension. It doesn't transfer like I think it should.... The bottom pic shows the rear of the suspension collapsed as far as it can.
http://www.totallyamaha.net/forums/showthread.php?t=49003
deep
deep
Boondocker-1
Looks like your suspenision is compressed way too much. Can you let that rear limiter strap out? Is your shock bent? I know with the proaction skids if both sides are not measured exact you will have binding issues. Did you call MPI for measurements?
-BD1
-BD1
deepnsteep
Yes, no, and no....I should explain a little better. I am not getting very good "transfer"...at least not like I had before on my pre-2000 skid. I had it with Hartman kit, transfer enhancement kit, and a 144" track. It really worked well for what it was. Now I have a Northern Lites chassis...all done up by them. It's pretty much everything they have down to the engine alignment cams. I would have all Denny's suspension arms, Al body shocks, Ti springs...more than I would ever put into a Proaction...lol. It had their adjustable transfer rods when I got it. I promptly removed them and put in a transfer enhancement kit. At any rate it does not "transfer" like the old skid. I can barely get it to carry the skis. I don't know if all that ski lift is good for going through the deep snow or not, but it sure is fun to ride like that!
The pics in that other post show the rear of the skid collapsed as far as I could get it to go. I was trying to show the lower portion of the rear torque arm not collapsing back like I remember the old skid doing. I thought the mount points might be off some. I believe all the weight would be basically on the rear axle in those pics...front arm all the way extended - rear all the way collapsed.
I'm not convinced that letting the front limiters way out is a good thing for deep snow. When weight transfers, the arm extends all the way to the limiter...creating a steeper angle of attack. I tried to go the other way and softened the rear shock and put the FRA in the upper slot.
Thanks!
BTW...I got 29" from the H arm mount to the rear torque arm upper mount.
dirtjumper895
Sweet... atleast my 29" measurement didn;t make me sound like an idiot!
