Diff Needle Flow Rates
YamerDown
Ottawa
Anyone know what the difference would be between a P-8 @ 4.0 vs a Q-0 @3.5? Is there a graph or something that shows the different flow rates of these?
Trying to figure out if one initially flows more then the other. Same for max flow.
Thanks.
i can give you the needle jet orfice diameters, straight from my aaen carb tuning handbook......P-8 is 2.69" and Q-0 is 2.7". the difference is only .010". my opinion is that they would flow pretty close to the same, due to the needle height.....4 on P-9, versus 3.5 on Q-0. i don't have any flow charts that have the needle jets you are asking about...sorry.
the flow rate increase is consistant between needle clip height & tube size. example: mopar says the difference between a P-8 & Q-0 is .010. that would make each of the 5 clip positions .002 richer progressively. which in turn would mean that Q-0 #1 position would be .002 richer than P-8 #5. so if you are @ P-8 #5 & still too lean in the midrange you would install a Q-0 tube @ #1.
bob
So I'm currently running P-8 @ 4, was going to switch to Q-0 @ 3.5 thinking it might be a little leaner initially, but finish off about the same. Last thing this setup needs is more fuel. Was actually considering the switch to try and save some.
Thought I read a post that said if you go past E-Clip 3 it was more efficient to go up a needle size and start @ 1.5 (or something close to that). Which is was lead me to believe there was a fair amount of overlap between them.
Anyone???
bob
bob, so if i'm understanding this right, when using the Q-0 nozzle and clip position #1, it would be .002" richer than when using a P-8 nozzle and clip position #1? then w/Q-0 nozzle and clip #2, you would be .004" richer than P-8 and clip #2? or am i way off?
mopar:
using your figure of .010 diff. between P-8 & Q0 would mean that P-8 #1 is .010 leaner than Q-0 #1. remeber each clip position on the needle is .002 x 5 clip postions = .010 total adjustability of the same needle per needle jet. this means that a P-8 #2 is .008 leaner than a Q-0 #1. P-8 #3 would be .006 leaner than Q-0#1 & so on.
bob
