03 viper 2800 miles with srx rear exchanger. Sled has never overheated. Rode this week in good snow and low temps. Red light and coolant icon started blinking 8 times then it would stay on. Now it will blink randomly and stay on too. Coolant is full and is warm to the touch and no boil over. Drove sled like this for 300 miles and had no problems. Unplug temp wire from sensor and it will blink 8 times. Now light seems to just stay on more then the blinking like it did the first day. Any info would be great. Thanks
cos in alaska
I had same problem once.
03 Mountain Viper. Same problem two years ago!
Fix: Inspected all connections in wire harness from temp sensor to instrument pod. Found connection at pod loose.
Hope this helps.
Hope this helps.
cos in alaska said:03 Mountain Viper. Same problem two years ago!
Hope this helps.
Hey Alaska, how did you fix the connection? I think I have a similar issue happening on mine -- exact same symptoms!
