Track Adjustment
jvizzacc
Livonia, MI
Just replaced the track on my buddy's 98 srx700. Got a good deal on a Camoplast predator [I think]. $360 shipped.
Anyways, got everything back together and the track is rubber-band tight. I have the service manual and tried to follow their instructions on how to adjust the tension, but it doesn't seem to work. Obviously there's something here that I don't understand. I know that the rear axle bolt has to be loose, which was the case, but it is still too tight. Which way [tighten or loosen] do I turn the adjusters to LOOSEN the track? Is there something else here I'm missing?
Thanks,
Jim
:EXER:
counter clock wise should loosen the track and you should have depending on the sled, .98 to 1.18" with 22lbs of pull. I use a fish scale...:)
