How do you remove the sway bar off a 2001 SXR 700.
T.S.U.Filmz
drill the rivets out of the plater where it goes into the bulk head and then pull the lil plastic things out
Or cut it on each side and pull it out and throw it away. Either way will accomplish getting it out. Just a matter of if you want to be able to use it again
