oil light on and off?
marty f
WATERTOWN,MN
why is my oil light going on and off it seems to be on during idle and goes off when i gun it so is the light there just to tell tou the oil is low or is it a bad sensor
sounds like the wire gremlin to me.... i have the same problem with my srx but only when i pin it...
From what i understand is that the oil light will only flash when the oil is low in the reservoir. it has no relevance to how much oil ur engine is actually getting (If there is actually enough oil in the reservoir)
Im pretty sure its how she works... but not 100% sure... though im sure another member will correct me if im wrong!!!
99.9% sure its the wiring though!
