Phazer stud patterns
BarneyMN
Minnesota
Anyone stud there old phazers? I put a 3/4 lug on my phazer stw and was wondering if it should get double backers or single. How about those star studs? 108 pattern for the 136, not studding the outside. Do they make a 3/4" stud or do I have to go 1", theres not much clearance there.
We studded my son's phazer this year with a new 3/4 lug track. I used studs from John Master's 1" push through with aluminum backers. 136" track is the long track which is what we used and the pattern was 108 studs " V" formaion. We just road over 700 miles combined between Minnesota and Michigan. No pull though and good traction. all stud are in the middel. for corninging we may put some on the outside of the windows. this is still up in the air. Note you must install tunnel protectors if you are going to stud a phazer or you will tear up the top of the tunnel. Side note the studs cost me $1.40 each complete stud, nut, washer good luck
