i haven't driven much this year and before i did wanted to get it all tuned up for this year what should i do as far as cleaning/greasing and all that good stuff thanks
1-Pull carbs clean check float adjustment
2-pull power valves clean then adjust(procedure here @ the site)
3-check/set other adjustments(throttle end play,oil pump,choke,all info here)
4-grease skid, front suspention with ha low temp grease.check track deflection
5-clean,wash wax,armerall,etc....
