Tripp700
Went to buy plugs for my 97Vmax SX, all sold out of BR9ES NGKR plugs. Crossed over to Champion 818RN2C. Has anyone else had to do this in a pinch?
you are right the part number is 4677,stick with tho'salswagg said:Their are two versions of the BR9ES. one with the solid terminal and one with the screw on. Check before you buy, the solid is more expensive but last's longer. I have had many sleds in the shop with the cheap style and the teminal stuck in the boot cap. The solid is the OEM replacement.
Undertaker13 said:No contest NGK!! nothing champion about a chump plug!!![]()
