drop down brackets for srx rear suspension
dave carpenter
Timmins Ont
where can o find drop brackets for rear suspension mount for srx ,has any one done this on srx ,and can you lower just the rear mount does in improve suspension
thanks dave
CB Performance sold them or some people including myself made their own.
You have to move both the rear and middle mounts down along an arc with the driveshaft as a reference point. If this isn't done correctly or accurately enough the suspension will bind and not want to move.
You really don't gain much with drop brackets. The benefits are mostly a better seat position, it makes the sled look more agressive, and the running boards sit higher so you won't get hung up as easy in deep snow.
The sled will be more tippy. You sit higher, and the center of gravity is higher. I believe it also hinders weight transfer to some extent. You sacrifice some handling. For my type of riding (offtrail, ditchbanging) I like the drop bracket setup. If I was running trails and needed flat turning and handling I think I'd go back to stock height. My setup was on the 03 Viper in my sig pic. I went to a Polaris skid and don't use drop brackets anymore, but I kept it at about the same height and it looks about the same as a 2" drop bracket setup.
