jordan
on a 01 srx is there an idle air screw or do you adjust idle with the fuel screw
jordan
anyone?
are you trying to adjust the engine idle speed?? thats on the carb rack on top.
jordan
thats what im tryin to do it appearantly had been adjusted with the throttle cable previously so where abouts is the idle adj. like the sled only wants to start if i give it a little throttle si its not gettin enough air and it only idls at about 600-800rpm
daman,give the guy one of your pics and point an arrow where the idle screw is.I would do it,but it is to much work..lol..
Just look on top of your carb rack you can't miss it big gold srew..
jordan
ok guys thanks for the info.
Millinocket Rocket
If that doesn't work your pilot jets may need to be cleaned.
jordan
is the adjust screw suppose to be located infront of the throttle cable on the opposite side of the linkage where the tors would be located because there is a braket with a whole in it but nothing there.
jordan
thats why i can't find it.. cuz it is not there.
WTF...thats not good,what hell did somone remove that for???
jordan
i have no idea the guy i got this from must be a complete idiot he has screwed so much up im gunna call him and give him hell over all this plus the blown engine its rediculous not that its gunna do any good haha but oh well
jordan
so will any bolt with a lock nut work or is it a special setup
you know put up a wanted add and a member will problably just give you
one if it's just laying around.
is your TORS switch missing then(that was on there too)
jordan
ya my tors is gone too the thing is im way up in canada so its prob easier for me to go to a wrecker than to have one of you ship one out
