suspension swap?
they are not a direct bolt in, the rear shaft is about 1inch shorter. if you look at an rx they have a thick bracket that the rear arm bolts to. this is offset to the inside. the one chance is talking about being a direct bolt in is the one i sold him. i knew what he was putting it in and changed the upper shaft for him before shipping. you can use the upper shaft from your skid or the hack way would be to use washers to make up the difference. if you are planing to sell your skid you are taking out i have upper shafts that i can sell you. for 15$ shipped, might be worth not taking the one out of your skid to change.
the rx skid is the same other than this shaft. all else is the same
hope this helps
That's right, I forgot you told me that, but I wasn't lying, it bolted right in. LOL Thanks BTV for taking the iniatitive for me and doing that. Great site, great people.
Chad
