slast
I have recently picked up a 79 Enticer 250 that I am restoring. I have looked in the Distributing Catalogue, and found some parts, but they don't have the following parts. Anyone know where I can find the following parts?
- Oil Filter, and oil line dimensions (need to know the size of the oil line)
- Fuel Filter, and fuel line dimensions
- Kill Switch (Rubber worn off so bare metal is showing.)
- Key Switch. Bought it with no key but it was rigged with a flat makeshift key.
- Primer
- Carb Kit for a KEIHIN carb. It's bigger than the Tillotson carbs.
- Windshield
- Oil Reservoir bottle. The nipple connecting to the oil line broke, and I need a new bottle.
Thanks,
Steve
- Primer
- Windshield
Thanks,
Steve
most of what you want is availible from kimpex. there was a member who was scrapping one of these for the oil tank. these never had a primer so someone added that. ignition, just wire a universal ignition in.
slast
Is there a link to the Kimpex Parts list or catalogue that you can forward?
Steve
Steve
i do not have one but the local canadian tire and a local autoparts store both can order from there. royal can as well but you have to go into the store. heck your local dealer sells kimpex aftermarket parts usually.
I found all the parts you listed minus the primer on e-bay. I searched under et250, et 250 and enticer. I find when you are looking for old parts e-bay is still pretty reliable.
how about dennis kirk. www.denniskirk.com
sandmanmike1
I have a oil tank. I will check out the condition. I am parting out my Enticer 250. I put my son which is almost 10 on our 900 mile 92 Indy trail 488. I just let him tool around the backyard. He is saving up for a new Phazer. Like from 07 on. Also have a Bravo 250 coming for my 6 year old daughter.
