79 enticer 250 - Need parts
slast
Ottawa, Ontario
I have a 79 Enticer 250 that I am restoring. I am looking for parts. Can anyone suggest a place where I can find parts? Royal Distributing only has some parts. I need the following:
- Oil Filter, and oil line dimensions (need to know the size of the oil line)
- Fuel Filter, and fuel line dimensions
- Kill Switch (Rubber worn off so bare metal is showing.)
- Key Switch. Bought it with no key but it was rigged with a flat makeshift key.
- Primer
- Carb Kit for a KEIHIN carb. It's bigger than the Tillotson carbs.
- Windshield
- Oil Reservoir bottle. The nipple connecting to the oil line broke, and I need a new bottle.
i believe the oil filter can be bought thru either marshall distributing or jr graham. the windshield can be bought thru jr graham too. the carb kit should be able to be bought from marshall distributing and will be made by spi. doesn't yamaha carry the carb parts you need?
http://www.denniskirk.com/jsp/tpl/c...c&leafCatId=&next.x=4&next.y=9&page=&limit=20
killswitch for $2
http://www.denniskirk.com/jsp/tpl/c...&leafCatId=&prev.x=13&prev.y=8&page=&limit=20
Windshield $38
Fuel and oil lines just go to the auto store and get good year hoses, just take yours to match size.
What do you need for the carb? If you need jets check out www.jetsrus.com
For the rest of your needs call this number 616-794-0086. That is a number to a sled salvage yard here in W. MI. He deals in vintage sleds. I am not 100% sure if he ships items or not, but I think he does, he will should have the rest.
