yamaha viper 123
I found this heat exchanger on ebay, and i am wondering if it will hook right up to the stock viper set-up or wil i need to purchase other items to make this work. Btw it is off sx-r 700(01), im not sure if it will work not being off the srx.
Link is below....
Heat exchanger link
Link is below....
Heat exchanger link
should work. only thing you have to watch is that the viper hoses are larger in diameter than the sx hoses. found that out when i put the srx cooler in the rear of a sx500r. we ended up making adapter hoses because i was going from small to large using a peice of pipe in the small hose and sliding the larger one over it. then we clamped it on the exchanger and on the smaller hose. there is a pic of the finished product on here. as long as you are not running pipes you should be fine. if you add pipes it might restrict the coolant flow too much because of the smaller diameter tube.
