TJ500
which years and models have "tall cover" primarys? Are these clutches a different model completely, or is it only the cover, and why?...
TJ
TJ
BETHEVIPER
Life Member
all srx, all tripples from i think 99 up.
the difference is just the cover, it uses a different spring design with a taller(about1/4in) standing height.
Turk
TY TECH ADVISER
- May 2, 2003
The 98 & up SRX,s. 00 & up triples single piped sleds. The difference is the longer cover. The rest of the primary is basically the same with a few minor change ups.You can use a larger variety of primary springs with higher engegement with less chance of coil binding the spring.Tall covers have a #8DF stamped inside of them
